04 husky wr250 exhaust valve question
richy
38
04 husky wr250 power valve - exhaust valve install question
Here's a quickie.
Should the 2 bearings on that sit on the exhaust shaft fit loosely on the shafts. Seems as though the shaft spins freely inside without spinning the bearings. I tried new bearings as well. Just want to make sure there are no tricks prior to slapping everything back together
richy
38
04 Husky wr250 powervalve assembly qustion
Should the 2 bearings (the ones that are sandwiched between the cylinder and exhaust cover) that sit on the exhaust valve shaft fit loosely on the shafts. Seems as though the shaft spins freely inside without spinning the bearings. I tried new bearings as well.
How much side to side play should there be?
also the exhaust valve bearings once everything is assembled can be easily pushed out by pushing on the ends of the exhaust valve and pushed back in by hand - is this normal?
Are there any tricks prior to slapping everything back together
Thanks! :bang:
Taliesin
121
Are they badly alighned or too tightly torqued down.Check this 1st.Never had any cause to remove them on my previous 250's. Has a WR & a CR version.
