tightwoods
- Nov 23, 2000
- 87
- 0
I'm changing fork fluid/seals and this is my first bladder fork. Can anyone offer the basic procedure for fluid filling, air bleeding, fluid height, etc.? Thanks.
tightwoods
tightwoods
DEANSFASTWAY said:Tightwoods on the bladder forks its hard to dispel thre air from under the spring base plate that rests on top of the cartridge .It takes a bit of time and some milking to get it(cart) filled you may want to try to dislodge the washer with a coat hanger or leave it out until after youve bled the cartridge . Sometimes its good to walk away for a few minutes letting things settle .Good Luck
