jrf4x4 said:No a belt sander would be fine, i'm just a machinist and just use to going by a drawing and doing with a mill.
SVandal said:Curious, why use a mill to bevel when a belt sander would do the job a whole lot faster? Is there that big of a concern about weld contamination from the sand on the belt?
SVandal said:You call those good welds??? Theres nothing there to grind down :).
karlp said:I had to use one of those fancy Fredette kickers. The stock one was just not going to clear the frame.
It might on your frame.
ebeck said:That pipe is way off, it is a 125 pipe, you can see the length difference. I'd look for a KDX or KX250 pipe. It may work for you though.
Just realize it WILL COMPLETLY change the character of the KDX motor. Enough that one would wonder why go to all the trouble to then loose what the motor has to offer.
hmm not necessarily. its really something that needs to be tried to feel the outcome. in reality, it may not be all that much different.
if it is no good, i only have about 40 minuites of work into it so no big deal.
ebeck said:Ohh, to the contrary, necessarily. It will be different. Pretty awful actually. On a 2 stroke the pipe is everything and that is not Hyperbole. Of course you may not know unless you have ridden a KDX with the correct pipe. It will work but it will not work well. the question is how do you know it is not working well if you have nothing to compare it to.
