canyncarvr
- Oct 14, 1999
- 4,005
- 0
It's got nothing to do with wise, that's for sure, but I can tell you it's so. I don't know if it's attributable to incomplete combustion or what. My bike blew spew all over the place AND lean-roll seized (I said that already). And I'm not talking about a 50 pilot with a 138 main running around at 1/4 throttle, either.
Where am I? Out riding, natch! Well, was then anyway.
The point is, don't jet by spooge. There are a number of reasons you'll get spew out the pipe that have nothing to do with whether or not you're jetted correctly. The way to properly determine a main jet selection is by reading the mixture ring at the base of the insulator after a properly run WOT plug chop. Some jet from the bottom (pilot) up, some from the main down. Whatever your method you will likely be doing it more than once to balance the carb correctly. While an incorrect pilot choice won't make a whole lot of difference at WOT, an incorrect main WILL change everything clear down to the bottom. Today, a main change from 152 to 155 pretty much wiped out the bottom end of my bike for example. Off-idle to 1/4 throttle dropped off severely with the single up-step in main.
I changed it back pretty quick!
I still want to hear that the original poster knows what a 4-stroking 2-smoke acts/sounds like.
