yup.... (blue seems to work fine, so far)kelseybrent said:On a side note, make sure you locktite and torque the kickstart nut, because that shaking will eventually shake it off the bike.
dan1608 said:Thanks for the replys. I changed the transmission oil last night and went for a short ride down the block. Seems to be ok. We won't be able to get to the woods for a couple of weeks to give it a real test though. Again, thanks.[/QUOTE
I've had the bike out and haven't had any problems since that first time. Like you I had just changed the transmission oil when the problem occured. My guess is I must not have put enough in. When I change it now I dump in the whole quart. How low trans oil affects the kick starter is beyond me. Everyone is right about those kickstand bolts they loosen up very easily.
dsndblm said:Well, I guess I better get an aftermarket pipe and silencer so I cant hear the noises!
Thanks for the input.
We use cookies and similar technologies for the following purposes:
Do you accept cookies and these technologies?
