- Oct 28, 2001
- 4,704
- 0
23jayhawk,
I'll take some detailed digital pictures of the WER mounting either tonight or tomorrow afternoon, and post here or e-mail them to you (send me your e-mail addy). I have an '02 220, so it should be the exact same setup on your bike. I am assuming that you have the same mounting kit that I do.
I did not have to drill anything into the frame gusset. The bracket fit snug up against the steering stem (although I did "snug" it using a small rubber mallet). The thin bolt went through the big (1") hole where the frame gusset meets the steering stem column.
It's also important to make sure that the WER pivot arm is as level as possible. I think I used the thick spacers to get the WER up as high as possible. Also adjust it so that the WER does not act as a steering stop. This will toast the unit in no time. The pictures will be helpful.
I have an X-Mas party tonight, so I may not be able to get to it until Saturday afternoon.
