Probably not, but I'm sure you'll have to remove alot of parts to get to it, look up parts fische yamahaoftroy should have that year on there or the 92 will work. If you can get to it with just removing clutch/water pump etc, try just taking a small screw, screw it in part way into the seal pull it out and then use socket thats close to the same size to tad it into place. Worked like a charm on the left side on a CR 250.
