98 yz250 Compression/Rebound settings
chillrich
34
I am looking for recomendations of setting for the compression and rebound on my 98 yz250. I do trail and track riding at a novice level & my weight is 190 lbs. The race sag is set to about 115mm and fork oil level is at factory spec of 135mm. The compression and rebound settings are also set at factory spec. I have moved the forks up in the clamps about 5mm and may increase to 10mm for tighter cornering.
The bike handles fairly well and doesn't seem to kick over square edges. My plan is to start experimenting with the clickers a couple of notches at a time but was looking for input first.
