r.2 stroke
73
Hi guys,
a friend of mine has a '94 Rm 250,and i want to help him set it up for enduro/woods riding.
We are going to put in softer fork springs & play around with the oil heights,also,try and get so fly wheel weights.
Any of you that have tied this,or, any advice greatly appreciated,
thanks,
Rog.:cool:
e.c.bert
58
Great Anything but Motocross Bike!
You'll have more fun with the early years ( pre-1996). I've had a1994 myself and the Showa forks work better with less compression dampening. Those darn dual-chamber forks were never meant to be short of difficult for motocross. Anyways, here's some suggestions:
*Stock springs front & rear ( turn comp. clickers 9-14out on the forks!)
*Procircuit Pipe w/ FMF Turbine core spark arrester/ silencer
( Put your flywheel money into the pipe purchase; the RM's light clutch pull and PC power delivery will never be a problem. I had a Stealthy flywheel and took it off; though for that model they're easy to install...so ???)
*Boyesen Rad Valve or Power Reeds. The Pro Series reeds will make the bike hit in the mid-range!
*With these mods you can goto a 14t countershaft sprocket! 49/50t rear; and keep up with the other 250cc bikes on the Fire Roads.
*BR8ES NGK spark plug:p
