mmz77 said:Very easy like this: http://youtube.com/watch?v=Y4fKUwgPfoQ
Also covered before... No need to worry about blown fork seals by compressing the suspension. The oil in the fork isn't under pressure. Old wife's tale.FruDaddy said:Don't strap it down too tight (just compress the fork an inch or two), or you will blow out the fork seals.
Never read the previous coverage, but if forks need to have the pressure released (the purpose of the screw), then they clearly do build pressure, and at some point ARE under pressure. Again, if the forks are not under pressure, then why do the bleed screws exist? I will accept that the heat generated by use creates the pressure, but exactly how much motion is requires for the build up?Patman said:Also covered before... No need to worry about blown fork seals by compressing the suspension. The oil in the fork isn't under pressure. Old wife's tale.
No they didn't.kx125412 said:My seals blew out from cranking the bike down too tight.
FruDaddy said:forks need to have the pressure released (the purpose of the screw), then they clearly do build pressure, and at some point ARE under pressure.
FruDaddy said:Just call me overly cautious. I also do not use the plastic fork savers since I once had a seal start leaking because I left a bike on the truck for a few days with the saver in place.
I think that I just had a random bad experience with the support, it didn't do the job that I bought it to do, so I stopped using it. I prevent the bouce issue with a set of wrap around straps. The hook goes into a loop on the strap, thus reducing the chance of it coming loose.rmc_olderthandirt said:The general misconception that I hear is that the fork savers will protect against seal damage, not the other way around. In reality, I don't see how it could hurt the seals at all and doubt that they would do much to protect them.
The plastic "fork savers" (better referred to as a fork support) do have a useful function, however. If you have your bike strapped down by the handle bars and then hit a bump that makes the forks compress (doing what they were designed to do) the action of the forks will make the tie dows go slack for a second. If this allowed the hook to fall off either end you could end up spilling the bike.
I believe the facts have been quite clearly spelled out both in this thread as well as several in the Suspension Forum.FruDaddy said::blah: :blah: :blah:
Badda-bing! :rotfl:XRpredator said:someone thought I blew a seal once.
I told him it was just mayonnaise
