bashn
65
My friends shock free-sags properly before riding, but after riding, the shock "sticks" somewhat and the bike tends to stay where it's pushed. He just had the shock serviced by a local shop and they can't find any problems with it sticking, even after heating it up with hot water. Has anyone else seen this problem? It's a '00 YZ250 KYB. What could make it bind with heat? The shaft is NOT bent.
Mark
marcusgunby
6,450
ive seen one do this after bieng serviced by PA but im sorry i never found out why-maybe the seal on the piston assembly is swelling more than the body so causing stiction but why i dont know.
bashn
65
We checked for linkage binding and that's not it. The seal swelling may be more on target. The shock body and piston are both aluminium and should expand at the same rate, so I can't see the piston binding. I was thinking maybe a seal/bushing was getting soft and "wedging" or misforming into a place it didn't belong. The weird part is the stiction always disappears when the shock cools off. It's been disassembled and inspected once already, with no apparent problems. It's going back again, but I have doubts as to the outcome. This problem developed immediately after the first service, so I'm convinced the tuner introduced this problem in some way. Maybe a seal was installed incorrectly or was damaged when the shock was assembled? :think
Mark
bashn
65
That sounds plausible. I'll check it out and post the outcome when the problem is finally fixed.
Thanks to Everyone!
Mark
Jeremy Wilkey
Owner, MX-Tech
Jan 28, 2000
1,453
Mark Shockut...
I've noticed that is a problem with the shocks more when they are cold or low on gas.. Should be intresting to find out! I had a guy bring his bike in with the rear colasped and stuck form that problem...
Regards.
Jer
Jeff Howe
456
Jer,
I can't tell you what it is for sure that caused it. 2 of the shocks were from KX's but none of them had been touched by PA. Is it possible that air pockets from cavatation would hold that needle up tighter. I've always wondered, though I never checked the pressure and never found anything out of whack internally. it's been awhile since I've seen it, better than a year now, but I'll do a better job of looking into it on the next one I get like that. It bothered the heck out of me why I couldn't diagnose it but I still think it had something to do with air in there.
But, heres something weird... I had a shock from a 01 CR125 few weeks back, brand new, never ridden on yet that had a measureable pressure of 120psi in it, factory charge!! I wonder what that would have felt like after a long moto??
shockdoc
327
Hey Guys I have had several KYB shocks do this. Mostly Kaw but a couple others also including a brand new 01YZ250. I have seen this in the last 12 months or so and this is what I have found so far.
I have replaced everything (even diff. oils) inside several shocks and found that the bodys have been the main problem. I was told by a couple other suspension builders that there has been some bad KYB bodies in the last couple years but not bad enough for any kind of recall.
I had a reputable machinest look at a couple of bodys and he determined that they were made egg shaped and that what was happening was that the body would swell and actually get smaller on the inside. He actually built a jig and pressed the body (from the outside) while keeping a dial guage on the inside and pressed the body back round. That shock is still working after trying a new OEM piston, and shaft assy first which didn't work.
The rest of the shocks I've just replaced the body and they have worked fine. The only thing I can't figure out is why sometimes its a brand new shock that hasn't been apart and sometimes its a 6 month old shock that has been working fine then all of a sudden 1 day it locks up as soon as it gets hot.
doc
bashn
65
Thanks for all the help guys. As promised, I said I would follow up when the problem was resolved. The suspension rebuilder measured the shock cylinder carefully and found it to be good. He then removed an o-ring that sits underneath (covered) by the bushing in the shock piston. Stiction dissapeared! I'm not sure what function this o-ring had, but the shock has performed fine ever since this change was made. :cool;
Mark
bashn
65
It was the stock piston. The problem may have existed before the first service and just went un-noticed. I'm not familiar with the design of the piston. I've seen the teflon bushings on forks I've worked on in the past, but I have not seen o-rings used underneath, above, or below those bushings. The way it was described to me, the o-ring was placed underneath the bushing.
Mark
marcusgunby
6,450
I did a friends 2001 RM 125(Showa) with only 10hrs riding on it and the seal head assembly was almost too tight to go into the body(sounded like sandpaper while stroking the shaft).The seal diameter was 50.3mm and the body was 50mm.I removed the o rings behind the teflon band and the diameter reduced to 50.1mm.It then ran smoothly in the body.He rode it and was happy with the performance.I will inspect it mid season and may end up refitting the o ring to take up any wear.
NO HAND
1,198
Marcus, I would apreciate to have a few advices on how to remove that teflon band. I noticed my shock sounded also like sand paper moving up and down so I bought a new teflon band along with the rubber seals under it. The problem is I cant remove the teflon band. It looks pretty stiff and hard to get through even with an x-acto blade :eek: Thanks!
marcusgunby
6,450
Seb i used a stanley knife and just cut through the band, making the edges the same shape as the ones race tech etc sell.
BTW the shock i did with no o ring behind the ring is still going strong.
FRESH VIDEO
