I bent the handlebars on my bike but it's not too bad. The left side is down a little and twisted back. I'm wondering if there is any way I can bend these back rather than getting new ones as I am short on cash for the time being.
You could try a long section of pipe to give you leverage. And try to bend them back.
Steel bars are $20.
7/8 Aluminum bars are around $60
I let my sisters boyfriend ride my bike, he felt the need to run it into a tree, bending my Pro-Taper 7/8 bars. I had a ride scheduled the next day. I had to use the steel bars that came with the bike. I just filled them with spray-expanding foam insulation, for a little added strenth and vibration damping.
I now have Pro-Taper taperwalls, they shouldn't bend anytime soon.
Try heating them up a little bit and bend them back with a rubber mallot, and do yourself a favor..when you get the money..invest in some pro-tapers....will not bend!
That's not going to fix bent bars, only misalignment. I would heat them up and bent them back with a length of pipe (with gloves on). That's how we bent back my old bars.
