Red_Rooster
- May 26, 2005
- 41
- 0
Has anyone had success with using the BRP oversize bar and stabilizer mount on the stock tripleclamp for a 95-2006 KDX? Scotts says it wont work without changing out the triple clamp. BRP says it will work just fine. Scotts says the issue is that the barmounts arent flat on the triple clamp, but that they lean forward (toward the rider) a bit, and mounting the dampemner has to be perpendicular to the triple clamp. Again, BRP says it will be fine.
I went ahead and ordered the protaper bars, Barmounts, Stabilizer mount (top bar mount piece). I have the stabilizer already, but neither Scotts nor BRP had the bolt on stabilizer tower in stock. Will I be ok? Any experience would be great. Also, what is the best source for the bar mount cones? should I use new stock cones, or get the Scotts cones. Will CR cones work, or are they different from the KX/KDX cones?
