fremontguy
579
Since we're on needle topic ,is the difference between N85D and N85E 1 clip position or1/2?
James Dean
137
CEJ is richer on the straight portion by .01mm. This will only have an affect below 1/4 throttle.
CEJ is 2.68mm vs CEK at 2.69mm
The N85 question can't be equated to clip position because it is the portion before the taper start which is different. Again, only having an affect below 1/4 throttle.
N85D is 2.68mm vs N85E at 2.69mm
These both run richer than the CEJ/CEK because of the location of the first taper start (higher on the needle).
James
fremontguy
579
Thanks for the reply on the n85 JD. I should probably leave clip in 1st position after change to n85e, instead of lowering to 2nd position I guess.
