KTA
288
how do you properly clean a spark plug . . . . i was playing with my carb a little today, and in the process fouled a plug. i took it out, sprayed it with some simple green, wipped it off as much as i could and put it back in. It started but died immediatly. So i took it out again, soaked it in some heavy duty degreaser, wipped it with a soft wire brush, dried it and put it in.. Doesn't fire at all. . . . . . how do you properly do it?.
OKKX'er
713
It's not really worth reusing a plug. keep a few on hand and just use a new one. You don't want the cleaned one to get you half-way up a slick, muddy, rooty hill and then foul again.
KTA
288
yeah... i usually keep a couple on hand, but it's my last one, and the shop is closed today... . i want to ride!
OKKX'er
713
that has never, never happened to me! Run some emery cloth through the spark path and clean it well with brake cleaner.
G. Gearloose
Pigment of ur imagination
Jul 24, 2000
709
Wire brush is the worse thing to do, it imbeds metallic paticles into the ceramic insulator, increasing its surface conductivity.
If your stuck, torch it, but best to Go New.
CO Dan
234
I use a little sand blaster I got from JC Whitney (about $8). It's a POS but does the job, then I blast it with lots of brake cleaner.
Works great, used to do it on my street bike too.
dave186
904
KTA, it sounds to me like your plug is toast. If it fired up and died, it either fouled again and you have carb problems, or the plug is just toast.
KTA
288
well.. . .i gave it one last try.. .. heated it up, soaked it in brake cleaner... started.. ..ran poorly for about 10 seconds and died.... . oh well, guess ill wait till tomorrow.
250motoxer
38
I have the same cleaner as mentioned above... mini sand blaster. Works very well, but never quite like new. Cleaned sparks plugs seem to work better for me in a four stroke engine... Still worth the investment if you already have an air compressor. I have had my plug cleaner for about ten years. Works as new.. :)
Jaybird
Apprentice Goon
6,452
Charlestown, IN
I've heard it all now.
