Joe_148
54
would it hurt my fork tubes (01 cr125) to clean them with gasoline? I had a vforce sticker on both of my fork legs and took it off and have tried vinegar, hot water and soap and nothing seems to work. The adhesive is stuck on there pretty good..anyone know what to use without hurting the tubes? thanks
Jaybird
Apprentice Goon
6,449
Charlestown, IN
Another Goof Off fan....
I think Home Depot has it.
Gary B.
684
Never used Goof-Off, but WD-40 usually works for me. Please, promise to never use gasoline except in the tank again! Way too dangerous :flame:
joe28kdx
235
I use lacquer thinner for every thing!
Keep it away from the seals, and it'll do a number on your hands if your hands aren't tough.
Brake clean on a rag will work, carb cleaner, ahhh ok, mineral sprits work ok, emanel reducer works fair too. Gasoline, neve use it!
Keep it all the cleaners away from painted or alm. or rubber and it should be fine.
Careful of those eyes, can't race with a seeing eye dog!
Joe
va_yzrider
353
I use goof-off all over my bike. If something is dirty, it gets a few shots of goof-off. It seems to work best on adhesives. I use it after I wash my bike and before applying formula 303 to the plastic.
Joe_148
54
oh my, this goof off works wonders! :ohmy: It took the stickerage right off soooo easily, then my mom used it on some gum that was stuck in the carpet and it took it right out. amazing stuff..thanks alot guys. Will it hurt the plastics? I read on the back it damages many plastics and said goof off 2 is good for plastic.
RM_guy
Moderator
7,046
208
North East USA
Goof Off won't hurt most of the body plastics on a bike. Always try new cleaners in a small, out of the way place first to see if it has any affect. Fenders, side panels and gas tanks are made of polypropylene and that are pretty much impervious to anything.
I buy Goof Off in the big can & I mostly use it to clean grease off the carpet that I track into the house. Don't tell my wife though. As far as she is concerned I've never tracked grease on the carpet :eek:
Joe_148
54
will goof off work good to get all the built up oil/grease around the sprocket from lube and some spooge near the header thats built up? man I just thought of that, it would work wonders. Should I use a toothbrush and rinse it off? or just a cloth like they recommend?
RM_guy
Moderator
7,046
208
North East USA
Goof Off will work but WD40 works just as good and it's cheaper. I always have an old tooth brush around to clean grungy grease and grime. You won't need a brush to remove adhesive. A cloth soaked in the stuff works fine.
