Feb 3, 2004
25
Can somebody please help me out
I need to get a new clutch basket for my 2000 RM 250 the problem is that it is about $500 canadian with taxes :yikes: . I was looking for a good used one and was wondering what other model years would fit this bike. I.e. will the assembly out of a 1997 fit a 2000? I spoke to 2 different dealers and one told me "yes" and the other told me "no" I figured somebody here could tell me. Thanks
mtk
1,409
A clutch basket is a wear part.
Buying used wear parts is rarely a good idea. Yeah, you might get lucky and get a decent one, but more than likely you'll just be buying another worn out hunk of junk.
trial_07
Play with gravity
1,430
A clutch basket isn't 500 $ canadian. I bought my brand new Vortex clutch basket (much better than original) for my 125 at 270 $ can. I know your cylinder is twice as big as mine but your clutch basket should be about the same price.
j32
Uhhh...
Jun 8, 2006
202
look the part numbers up on microfiche.,and see if they are the same
if you have grooves in the tabs-- you can file them smooth again ,i have done this to a buch of baskets it works ,you should get a nother season out of it
Feb 3, 2004
25
Inner Basket - $316
Outer Basket - $101
Not including tax - So, 417+ 14% tax is pretty close to $500. Help me out if you know where I can get it cheaper.
The bike stalls when I put it in gear, so I took it to the garage, the mechanic took out the basket and told me it need to be replaced - do you recommend filing or should I replace?
trial_07
Play with gravity
1,430
Filing will work only once and that is if the notches aren't too big. Afterwards the basket will wear much quicker. Did you take a look at vortex? What is the outer basket you are talking about? Do you mean the pressure plate?
richardgd
10
I had a 2001 RM125 with the same problem, grabby clutch. Each winter I would pull and file the basket and it would get me thru the year. Last year I finally got tired of filing so I bought a new billet aluminum basket made by Performance Engineering for $150 US. I just checked and you can mail order one from Motorsport.com for a RM250 for 139.95US. I also replaced the clutch plates and springs at the same time and was very happy with the results.
