Moto-Chains
- Aug 15, 2005
- 5
- 0
The clutch basket on my daughters kx60 has groves some as much as about .020". I don't really want to replace it, it isn't bolt on, it appears to need to be pressed or riveted to the gear behind it. The question is, how much wear is too much wear, and what if I filed the groves out or smoother would this be worse or better. Its problem is just flakey operation of the clutch - erratic. Adjustments don't stay the same from one lever pull to the next.
