CRrider20
15
just recently i was taking my clutch out to get to the gears n while i was trying to take the bolt off the inner clutch hub i snapped one of the five towers that the screws go into with the springs if i were to use this as only 4 remaining would i risk any damages n would it hold up i dont mind the clutch not catching to good cause my plates are fried ne ways i just need to use it for a short period of time cause that dam inner hub is like 260$
viking20
428
Do not ride it ! See if you can get a non-oem part , or find one on THAT auction site , if you have to ride now .
Think of it this way: If your clutch slips , it generates an enormous amont of heat , and the oil will get real dirty because of all the debris from the plates. It could ruin your gears , and/or the bearings in the gearbox REAL quick !
I guess you found out the hard way that its nessecary to have an impact gun for this job ?
