2001 YZ 125N. Clutch looks Fine, Bike runs Great. New Lever, Cable. Wondering if the bearing/washer behind the part that actully pulls the clutch togeather if worn can cause this to happin.. thanks
When you say the bikes dies when the clutch is pulled in I'm assuming you are putting it in gear??? If that's the case, the clutch basket may be notched, not letting the clutch plates slide.
