I don't understand all this talk about using the clutch in the corners. I down shift using the clutch on the way in and then upshift with clutch on the way out. What else do you use the clutch for in the corners? What, when, and why would you "feather" a clutch in the corners?
Is it OK to shift with out the clutch? Can you upshift without the clutch under power? Can you down shift with out the clutch? How often do you not use the clutch, 25%, 50% 75%, more?
If I only use one or two fingers on the clutch lever, then I don't get full clutch level travel. You know, my fingers stop the lever from hitting the hand grips. Is that OK, to shift with one finger on the clutch lever with less than full clutch lever travel?
Thanks in advance for any help. I have gotten some great advice on my other riding questions.
