skiboyracing
- Jan 22, 2006
- 85
- 0
I bought a 1999 Cr250 that had been dunked in a mud hole. Long story short he tried to start it before he drained it. Of coarse it was hydrolocked so he then drained the water out and got it to run. He road it back home and when he came back it had no compression. Well I picked it up for a few hundred bucks and tore it down last night. The top ring was toast. Very thin. Luckily the piston is in one piece and the rod is nice and tight on the up and down motion.. My question is, I notice when I roll the crank over there is oil in the bottom of the crank case that is just high enough to coat the crank as it turns. It looks like tranny oil. I don't remember this in any of my other bikes but it's been a while since I did a rebuild. Should there be oil in the bottom of the crank case that lubes the crank or should it be dry. I was thinking the lower end was all sealed bearings but I can't remember?
