B
biglou
Here is a picture of my buddy's 99RM250 drain plug area. There are two problems. 1) The case is cracked, and 2) The threads are all but gone. Here is my plan, just wanted to see how many of you concur:
I have stop-drilled the crack with a 1/8" bit to a depth of about 1/8". My plan is to grind a groove following the crack (including the bolt head seating surface) and then heli-arc it and then grind/polish it down, taking extra care to get the bolt head seat area flat enough for the copper washer to seal.
Secondly, I intend on heli-coiling the drain hole. I have one question-Does the heli-coiled hole accept the same drain plug thread size as before the repair? Just curious because we have a brand new magnetic drain plug to install.
So, does my process sound reasonable? There's no getting around having to heli-arc that crack. This thing was leaking badly.
Here's a close-up of the crack:
