Hi all, I have a 1997 rm 125 and I just installed a new piston and ring. Just one question. On the side of cylinder (right side) you have to take a civer off to get to the other nut to remove the cylinder. Just forward of the nut is a hole that leads to the clutch side of engine case that has a rod that is in there but is loose. It isnt attached to anything on the cylinder. What exactly is this and what is it supposed to hook to. Once I removed the cylinder it dropped down into the side cover. Any ideas. This rod is very small and has a couple bends in it and then is horizontal at the top. Thanks for the help in advance. Steve
