azcab
35
I'm real close to buying a clean 1996 Dodge Ram 1500 5.2L v-8 318, longbed, x-cab, 4x4. I would occasionally tow a 18-24 foot camper trailer, with the truck full of bikes. Is this enough engine to tow comfortably over Colorado passes, etc...? I haven't bought the camper trailer yet, but I'm guessing a 18-24 foot would weight around 3500 to 4500 lb.
Any advice would be appreciated.
G. Gearloose
Pigment of ur imagination
Jul 24, 2000
709
Unless the gear ratio is in the low-4's or better (unlikely on a 1500) then it could be mediocre with a std, perhaps worse with the auto. I suspect you will have to push it to the boards anything steeper than 7%. The advertised power levels from dodge seem optimistic according to owners I know. And it also depends what you consider 'comfortably'.
Unless the gear ratio was good, I'd keep looking, no lower than 4.10 w/318, 3.73 w/ 360, but better yet the 4.10 and 360 combo.
justql
2,873
NO.
I just traded a 96 with the bigger V8 for a deisel. I pull a 23 ft tailgator with three-four bikes. Terrible fuel mileage and not alot of power.:(
NVR FNSH
1,235
No. I drove a '96 2500 4wd 360 V8/auto with 4.10s and it sucked - both fuel and power wise. I towed a 6x12 Uhaul trailer (tandem axle enclosed) up the grapevine and was seriously disappointed with the power. With two bikes + gear in the bed it would ping on 87 octane going up the grapevine.
Brian
Jay D
10
If you look at the torque curve for a 318 vs the 360 you will see that the 318 makes better power where you need it for towing even though the 360 makes better overall power. I would take a 318 over a 360 but would probably buy a Cummins.
azcab
35
Thanks for the opinions. I decided to go with a new Tundra with the 4.7 v-8. Not a huge engine but I know it pulls mid-range loads (4500-6500 lbs) pretty good, so it should work fine for me. After further investigation, I found out the Dodge had the 3.55 gearset and did not have the factory tow options (tranny cooler, big radiator) as the seller had mistakenly advertised. Thanks for the info.
