mattb348
204
easy exhaust gasket question
I bought a new pc pipe & silencer and noticed that it had no oring/gasket for the pipe & silencer.
Can I just use the ones off of my old stock pipe/silencer? Also, is there supposed to be a gasket for the silencer where it connects to the pipe?
Lastly, I noticed that there is an FMF spring/gasket kit for sale online, and it comes with 2 springs and 2 gaskets for where the pipe connects to the engine. Would this fit on my pro circuit pipe?
BubZ
13
Should Work
I suspect that the old o-rings would work if you used a bit of RTV sealant. The pipe silencer junction does not have a gasket, once again a small bead of RTV will seal the deal.
The FMF kit will work and may be a good investment. I have always had good luck re-using the the exhaust o-rings, but the springs can get clapped out and cause some really crappy exhaust sounds that are hard to track down..... :bang:
BubZ
mattb348
204
BubZ
What is RTV sealant? And do I have to use it on the silencer/pipe junction?
I noticed that my old pipe has this round rubber tube that seems to seal the silencer to the pipe. Do I just take that off and put it on the new pipe/silencer? Do I have to use sealant with that?
MXSparx
Mr. Meltsomeglass
Jul 25, 1999
3,724
71
NoVa
Sealant hardens when exposed to air.
RTV means "room temperature vulcanizing" and will harden or cure without a heat gun or other heat source.
With stands temps upto 500 degrees F
Can be found at most autoparts and hardware stores.
