RECENT POSTS
Exhaust Question
My exhaust is blowing oil out around it... I was told there's two o-rings that are supposed to be in there.. I suppose mine are bad.. Where can I find them at? Oh and I have a BILLS pipe.
Thanks,
Ryan
IndyMX
Crash Test Dummy
Location
Amo, IN
#2
Thanks,
Ryan
The CR125 uses a metal seal. It sucks.
You can get one at your Honda dealer or at bikebandit.com
I took the header off of my engine, cleaned the piss out of it, and put a bead of hi-temp silicone around the base. Let it dry a couple of days and then put it all back together. Makes a much better seal.
Only drawback, it doesn't last very long. If you take the pipe off for any reason, you'll need to redo it.
yep the metal ones on the cr's suck. I dont even know how they work! On the upside, the 2 o-rings for my yz cost $30 a piece. I havent even bothered buying them, i just line it with silicone.
