2001 KX250, I can't get the F*n bearings out. I have tried to heat the hub a little and get them out by using a socket. Should I be driving it from a certain side? I read about using a screwdriver or a punch. And I also read that you get at the bearing once there is space between the spacer and the bearing. So do I knock the whole bearing out using the socket or do I try to get at it form through the axle with a screw driver. Any suggestions? Would free all be ok to spray in there?
