rmmxzrider
every time I turn on the gas, gas leaks out of the overflow tube and the tube that drains out of bottom and it wont stop leaking. I just clean out the carb and adjusted the float in the carb and now when i turn the gas on it leaks everywhere.
need alittle assistance, thanks
robwbright
2,283
Not likely this, but it happened to me. . .
There was a very small crack in the threaded area of the drain plug/screw of the carb. This was allowing leakage even though the float was fine.
More likely what they said, above.
