hello from ohio
hi all
i just purchased a 04 yz450f and i need the basics
what maintenance needs done how often and with what products?
also i need a manual really bad can anyone help?
andy
-Change oil and oil filter every 2-3 rides or 1-2 races.
-Soak, clean and oil your air fliter every 4 hours of ride time
-Lub chain a couple hours before riding. I take my chain off as needed to soak and brush clean.
-Check/adjust valves. I check my valves every five hours of ride time to make sure they are in spec. I keep a log of the clerance and this helps me keep an eye on the top end.
This is a list of the simple mantinance that I do to my 450. If you do these simple things your bike should be good to you.
Have fun!!!!
what weight oil do you use?
what brand of oil filters and air filters do you use?
i really need a manual
