Hidden oil seals on the fork cap/compression unit.
Dvraptor
25
How do You change the oil seals that seals to the shaft on the fork cap/compression unit on a Showa twin-tube?
To be more specific: The rubber seal that is located under the alumnium ring holding the teflonbushing and o-ring.
I know it can be done, but not if You ask your local dealer only supplying original Honda parts... They want You to buy the complete for cap for around 60$...
Jeremy Wilkey
Owner, MX-Tech
Jan 28, 2000
1,453
D,
The seals can be changed by removing the stem from the unit. Place the stem in a shaft block and unthread it. From there just remove the piston unit. You will need to then remove the old oil seal.
Regards,
Jer
