I am in the process of installing an ims tank on my GF's KX100.
Anyone else had problems with these in that they do no F@#!@#%#%#%ING fit?
At the bottom the fuel line touches the engine cylinder. Seems bad to me, but there is no other choice. Also the spark plug only fits if it is done up first, and then it stretches it (it actually pulled the boot off once - just pushed it back on - hopefully it is not screwed now too) and piches it between the frame and the tank. No other better routing is possible.
I know it is supposed to be the right tank since it says KX100 right in the molded plastic, but WTF? Why will it not go on?
Is it possible that there is something different about my GF's 1998 that is the problem? Like when they say it fits a range of years they are just guessing and no-one tried it on a 98?
Or is there some trick I am missing?
I called their so called tech support and got "Well I've never installed one on any KX100's before, but it should fit"
Anyone here ever done one on a KX100 and have a tip?
Thanks,
Phil
Thanks,
Phil
