OK in theory if your bike feels about right and you start going over bigger jumps ( higher G loads) and you increase compression damping (both ends) to handle the jumps, what should you do with the rebound damping? I would think it would be the same but I'm not sure. I left mine the same and it seemed like the back end didn't track as well on the high speed bumps (it was a little skittery in 4th gear) and was bouncy on the whoops.
