motorpsycho
- Jun 8, 2003
- 20
- 0
Rhon, you may need to remove the slide assembly from the top of the carb as well. Just unscrew the black cap and pull the assembly straight out.
To get at the pilot jet, simply remove the four screws mounting the float bowl to the carb and you are there.
Do not remove the floats themselves! But be careful that the float pin stays in place.
Good luck!
Good luck!
