what kind of alternative fluids are you guys usings in your clutches? i've heard of using sythetic atf and 2.5 wt fork oil. from what i know about hydraulics, the light the fluid the easier it flows, therfore reducing clutch pull. the 2.5 wt fork oil sounds like a good idea. atf is approx 8 wt, making for a harder pull. both fluids have the same compressibility, leaving the clutch pull directly related to viscosity.
tell me if you think i'm wrong, doubt it
marc
'01 520 mxc
marc
'01 520 mxc
