Just got a 2000 CR125 today, WAHOO!!!! :cool: it's sooo fast and great! But it's my first 2-stroke, and modern bike,('88 Xr250 was my last bike) and i need help setting it up. First off, how much sag should i run? How do i adjust the rear suspension? Should i adjust the forks, if so how? i weigh 150lbs. without gear and am 5'9" and i am a novice rider(i know how to ride, but i still need to practice). Also how long until i should change the top-end and pistons? Is it hard? How many hours until i should chang the gear oil? Is the honda HP Gear oil good to use? Also is 32:1 using Honda HP2 and 93 octane gas a good ratio? How long until i should change the coolant, can you change the coolant? There is a lot of vibration going to the handlebars at high RPMs, so much that after around 45-60min i have to give my hands a break(even though i wear gloves), will i get used to it and i have a set of CR mid protapers will putting them on help? And lastly is their a website that has tech information on CR125's?
I know there are a lot of questions but i dont have my owner's manual yet(it's being sent to me) I LOVE MY BIKE!!!!!!!
Thanks for the help!!! :aj:
