julien_d said:Sorry, you didn't provide sufficient information for any sort of helpful response. I can tell you that you need three things for it to start. Fuel, air, and a properly timed spark. QUOTE]
compression helps too buddy :cool:
Bingo.1990kdx said:the gas is about two-three months old.
+1Joburble said:First things first then. Drain carb and put fresh gas in it
1990kdx said:it has fuel, compression 185 psi , spark, air. the gas is about two-three months old. it is 25 degrees during the day so i put heaters next to it for 3 hours and it still would not start .i kick it over about 100 times. i noticed that there is not a gasket on the exhaust pipe and it leaks when i kick it over
Already said that :nener:sr5bidder said:leaks what? air: then check for pluged up exhuast sytem
Amen.Joburble said:C'mon Mr 1990kdx hows it going? One of the great things about this site is that we all get to be educated when a problem is solved enabling us all to give and get better suggestions next time.
1990kdx said:sorry havent been working on my bike. i did get it to start three times and staying running for about a minute each time. had to kick it 100 times to start it the first time then about 80 the other two times.
