Coolector said:When the clutch cover wasa of did you check and set the adjustment nut. It should be turned in until it feels tight the back off a half turn and then locked with the lock nut.
PE175 said:The guy went to put brand new plates and springs in it, and after doing so the clutch wouldn't grab... It worked before he messed with it.
