cjrepdog said:Would be better to just replace the springs and seals in the stock forks? Is that a huge job that I will need special tools for?
I plan on doing a little more mx in the future, but still want to be effective in the woods.
cj
glad2ride said:SVandal, the bearings need to fit the frame, so that may be an issue.
glad2ride said:I was referring to your idea of a Honda CR and KDX swap. Have you tried to test fit the stem?
The lower KX bearing is the same. The upper is not. Otherwise, it would be super easy. :-)
