slapshot1540
- Jul 27, 2008
- 53
- 0
have a 1988 kx125 wasnt sparking cleaned off the coil and all that made sure everything was grounding and connecting good. then took the magneto cover off and kicked it and it sparked. so i put the cover back on ,put the plug in the head and it wouldnt run. took the plug back out and no spark. took the magneto cover back off and there is gas leaking through the crank seal. is gas getting in there and messing with the stator and the magneto and causing it not to spark?
