First of all, thanks for the great input on this website. I'm a first time KDX owner (2001 - 200) and have learned a lot on this website. I have searched and haven't seen this topic.
I'm checking my float level. Typically, I think it's too high. I'm having a little difficulty with the typical level check by measuring the float vs. bowl mating surface. The float bowl pivot pin is so loose it falls out. I have to hold it while doing the measurement. The loose fit changes the measurement a little depending on how it's weighted (upside down or not). I think this may be why my level is too high.
Are the pivot pins suppose to be this loose? I think I can adjust it as-is holding the carb right-side up such that the float weights the pin normally. Has anybody seen this before? Is it normal? Any ideas or opinions would be appreciated.
