mischi_punk
- Aug 2, 2004
- 81
- 0
My bike ('94 KX125) Started making a wierd noise this past weekend. It didn't happen all the time, only ocasionally when accelerating, when entering the powerband, and when blurping the throttle while coasting. It makes a high-ish pitched whine or squeaking noise. It sounded like it was coming from the gearbox, the left side slightly more than right. The sound only came when actually driving, not when holding the clutch or in neutral. It has always made a sound when driving, but it didn't sound bad, as the whining did. (forgot to add, the reg sound was a bit louder than usual though) Also, If it matters, it was quite cold outside (30's) and the bike had only been running for about 1/2 an hour before the noise occured first. I shut it off right almost right away, as I was sorta worried that something was wrong. I went back outside maybe 10 minutes later, started it, and within another 20-30 minutes it returned, much to my demise! it was off and on, only occuring for a couple minutes. Lastly, I don't think this is it, but my chain is sorta lose. I am going to tighten it up soon, but I doubt this is the prob.
Thanks to anyone who helps, I pray It is nothing major. Maybe it was just the cold or the clutch slipping?!?
Thanks again
Mike
Thanks again
Mike
