So I just got a 2003 yz250, and I've been going through the bike and just doing some needed general maintance, but when I went to drain the oil and evaluate it the top of the drain plug bolt was rounded off and I could not break it loose with anything.
Since the aluminum is soooo soft on this bolt head the situation quickly became worse. So I purchased a bolt extractor and a drill bit to accompany the size of the drain plug so that I could hopefully manage to get this thing out.
After spraying and letting pb blaster penetrate for over a day I drilled my bit into the drain plug and then proceeded to use the extractor and t handle tap to break this thing loose, but the d*mn extratcor bit broke off inside the drain plug.
Now I don't know what to do next. Am I screwed or does anyone know how I can get this drain plug out? Any help is greatly appreciated.
p.s. It hasn't budged any yet.
