I found a white mitxture in gear box . Would u belive that the coolant had little to no oil in it .
belive it ! So i pulled motor , split right side case and inspected . Everything looked good , My only concern is the water pump seal . It looked ok ( springs were there ) , concern was the journal on the water pump shaft . It looked like it had had friction burn from the seal , acctually it wwas particularly shiney in two spots of the journal ( assume from the garter springs ) .
Could below zero temps cause this seal to fail ? my biike was in the ol'mans SHOp and over the winter it got cold in there .
I can't think of no were eles were the coolant would mix with the oil , beside the gaskest of course .
So like the fool i am i reassmbled the bike & took her for a ride , Its kinda hesitating ,,,,,sort of like , the power valve is jumping up & down ( like a hookers pants on pay day ) .
My question is
1 . is there anywhere the coolant could mix with the oil
2. anyone had these types of symptoms before
I am no stanger when it come to taken this thing apart , just could use some feed back
thanks all
My question is
thanks all
