Parts Schematics for 93 CR250
I recently got a 93 cr250. I love the bike and its in pretty solid condition. It does need some replacement parts though. I checked on bikebandit.com and they don't list the cr250 for my year (or several other older years).
I believe I could use their parts wizard to find the parts if I had the numbers - but I haven't been able to find any schematics yet. I use buykawasaki.com for my kdx200, is there a site like that for older cr's?
Thanks for the help.
tony91
Subscriber
Troy-Racing has the schematic for the 93 Cr250. Click HERE for the link. BTW, I have the actual microfiche film for that bike. I also have a bunch of spare parts for that bike. Anything I can help with, just let me know.
T
Thanks for the quick response Tony. I'm checking out the Troy racing website right now. I'll let you know if I need any parts. If you get a chance, check out my other post. Maybe with you having pretty much the same bike, you can shed some light on how I can get this bike running closer to 100%.
Thanks,
John
tony91
Subscriber
Did the hard starting start after the addtion of the V-Force ?
Tony
tony91
Subscriber
Also, for my bike, on a new top end the compression reading was 170-180psi.
No, the hard starting has been the same with the old reeds and reedblock and the vforce. I had hoped that the vforce would take care of the problem - thinking maybe the old reeds were worn and not sealing properly.
I thought the compression seemed somewhat high, but I haven't seen any specs in the honda service manual on the operable range. Also, from what I've read in other posts, the results of compression tests are only moderately useful (best used to indicate when compression is dropping from when top end was new).
tony91
Subscriber
I agree on the compression test. I would seem to think that your starting and performance problems are probably due to jetting. I think that our summer-time jetting would be about the same. I'm not sure of my jetting #'s off hand, but I will check them when I get home. My bike has a rad valve, PC pipe and silencer. What's your set-up and what kind of gas do you run.
T
Im also running the PC pipe and silencer, vforce delta 2, 93 octane at 40:1 with yamalube.
I haven't touched the jetting on this bike yet....It doesn't seem to exhibit any of the symptoms of incorrect jetting. No boowaaaa sound or excessive smoking (heavy smoke when started cold but disappears once warmed up). When wicking the throttle wide open the motor doesn't bog, but the bike does seem to take a second to return to idle.
I assumed that I would probably have to tweak the jetting after putting in the vforce - I thought it would require slightly leaner jetting. But like I said, after the install the bike didnt seem to run any differenly.
When I get a chance I will try and crack the carb open and see what jets and needle it has in there. Also, is there any easy way to get the carb off on this bike??? It is way more of a pain in the ass than the kdx. On the cr the reed block manifold and air intake boot offer virtually no clearance for pulling the carb out and putting it back in.
As far as I know the previous owners never installed a flywheel weight - course that doesnt mean they didn't.
I don't know much about flywheel weights, am I correct in assuming that I can visually check if one is installed by removing the left side cover by the countershaft sprocket?
