I went riding yesterday with my 90 KDX200 with a new #52 main and #1173 needle. It ran great for a while, but all of a sudden it started to bog a little in mid throttle. It also was hard to start, and finally I would not start it at all. I checked plug and it was white and wet(looked ok other than being wet). put a new plug in it and it still would not start! Drained carb and then it started, turn on gas(peacock) then it would bog and stop running.
So for my bike to run I had to turn the gas off and ride a little then turn it on enough to fill the bowl and on and on!
Is the Float stuck? no gas is coming out of overflow hoses, Dirt in the float valve?
Has anyone had this problem!
Maybe tonight I'll remove carb. Hopefully the problem will be noticeable. Those 2004 KDX's are sounding pretty good right now!
