R. Phillips
- Sep 10, 2002
- 19
- 0
I've got a 2001 kdx220r that's been fouling plugs since I bought it (used) 2 months ago. Plug is wet fouling. I had carb cleaned & checked. I run 32:1 mix. Clip on needle was moved to 2nd notch from top. Cyl compression is 120psi. Bike smokes (white & a little blue)when cranked, and has a sputtering miss until I crank it up thru the gears. When I put a new plug in, it runs great for about 30 minutes, then loses power and starts a little miss. If you have an idea, please let me know.
I could take it to a shop, but would like to learn to work on myself.
