I did a top-end rebuild and everything was going fine until it stalled. I opened it back up to find the power/exhaust valve had seized and the arm broke off of it. You know what happens next...the piston smacked it a few times. Luckily, I think I might be able to get away with only replacing the valve. Check out this picture of the piston and tell me if you think I should replace it (click to enlarge, I circled the worn spot)?? I hope not, cause I only have about 30 minutes of riding on that biotch. I also did a compression test and it holds 60 lbs. I can't find any benchmark for this, so does that sound good?
<a href="http://img21.imagevenue.com/img.php?loc=loc299&image=73103_CIMG0030.JPG" target=_blank><img src="http://img21.imagevenue.com/loc299/th_73103_CIMG0030.JPG" border="0" alt="image hosting by imagevenue.com"></a>
