KiDX
404
My 250 refuses to start unless i squirt some starter fluid in the air box. I've tried everything. Starter fluid seems to be the only thing that works. Is this normal?
Mac
505
Try the easy things first.
-new plug, let us know what the old one looks like, wet, dry, fouled?
-clean the carb and check float height
-check compression, should be around 150psi
-how old is your fuel??
If none of the above seem to help then you may have a weak spark, check all your electrical connections, your bike will run with weak spark but will be hard to start.
After you get the bike running with starter fluid does it stay running?
dirt bike dave
5,348
It is not normal. Make certain that you DO NOT twist the throttle at all when kicking the bike if it is cold. Put your hand on the cross bar if you have to.
The procedure that always worked for me on my KDX250: 1) Turn gas and choke on, kick it over gently a few times to prime the cylinder,
2) bring the piston to top dead center (feel the compression, just as it gets easier to move the lever, you are at TDC),
3) then raise the kickstarter back to the top and kick has hard as you can.
Also, if your rings or piston are shot, the bike will become harder to start.
Canadian Dave
Super Power AssClown
Apr 28, 1999
1,202
Great suggestions guys :) , I'll add a couple things. Is there any way this could be a lean pilot circuit issue? Is your air screw cranked way out, is the bike jetted for high altitudes or hot temperatures and you've relocated it to a lower altitude or cooler temps?
Try tilting the bike over until you see gas at the carb vent then give it a kick.
David
Formula
59
C Dave you say a lean pilot. I kept going down on my pilot to help low end, as I did so my starting got harder. I thought the choke would take care of fuel at cold startup?
Also do low tension reeds help starting(Boyesen Dual stage) since they are more sensetive at low RPM?
No it's not a KDX but the theories behind this still apply.
Thanks again
- And lets hope we get a little rain before we burn down the province - just hope a bike never causes it or we'll be banned from everything.
Canadian Dave
Apr 28, 1999
1,202
Will Boyesen reeds help? I expect they would by they likely aren't the solution to your RMXs hard starting problems unless the reeds you are presently uses are worn past their service limits then changing the reeds to either the stock or Boyesen reeds would be a big help.
At start up the engine is cold so the incoming charge or fuel easily condenses on the cylinder wall, crank, case etc etc and not enough fuel is vaporized to allow the engine to fire. The fuel is there just not in a form the engine can fire. The choke dumps additional fuel into the engine so that there is enough vaporized fuel to fire due to the shear volume of fuel. Fuel is drawn into the cylinder via the pilot circuit so as the size of your pilot is reduced so is the amount of fuel at start up.
Try to get MX Tuners attention on the Performance Forum. He ran RMXs for a number of years and can likely give you the guidance you're looking for. I'd also suggest calling Jim Couster at CC Cycle in Westlock. He has a pile of experience with the RMXs including trips to the ISDE.
David
