I Have A 2001 Kdx 220, Stock No Air Lid, At Sea Level With High Temp. And High Humidity I Should Go Down In Jetting Sizes Right ???
Stock At 42 And 145 --- I Was Going To Try 40 And 140/142.
Any Input Would Be Appreciated!!
Thanx, David
Looks like a move in the right direction. You'll likely find that you need to lower the jet needle by moving the clip up one position as well given the high humidity ant temps in your area. The 220 can be picky about air screw position so you might find that you need to go back to the 42 pilot but with a very small air screw opening, say around 0.5 turns out.
You might also consider playing with different jet needles as well.
